Hi!
I'm trying my best to repair my Macintosh Classic. It's completely dead - no sign of voltage on mainboard connector/hdd connector.
I've already reccaped the analog board. When i was measuring things around i've noticed that all pins (8-14 so i guess it's the secondary winding?) on one side of transformer are all shorted to ground.
Well that doesn't look good, right? I've desoldered the ZP1 to check it outside of the circuit. Looks like i have direct short between pin 12 and 11, but the schematic shows some kind of connection there (coil?)
Pin 10 is ground, and it's directly connected to pin 11 - so 10, 11 and 12 connects to ground -am i missing something here?
I've measured the board without the ZP1, and there are no shorst between pin 8 to 14. Short appears only when ZP1 is soldered in place - especialy when pin 12 is properly soldered.
And of course - i'm not getting any voltage out of this transformer, 0v on all pins. Input pins on primary side shows ~300v and around 3-5 volts on another - are those values okay?
Does any of you know the specific transformer part# or know any current replacement for it? Googling around for 'tr204s-i2' or 'ETS39K545A 083g' doesn't give any results. Can't find any replacements
Any help/tips? i'm looking around for another analog board, preferably working one.
