I've just finished recapping an SE/30, and have a puzzling problem: while the boot chime is loud and clear and sounds normal, playing any sound while the system is running causes it to lock up and play a 'stuttering' boot chime for a second or two, and then restart - as if somebody pushed the reset button a bunch of times in quick succession. Other than this fault, the system seems fairly stable - SCSI, ADB and Serial work fine, and other than the sound test, it passes Apple Personal Diagnostics just fine.
There didn't appear to be any corrosion damage to the logic board, just a bit of crusty electrolyte that I cleaned up with warm water and detergent, followed by isopropyl alcohol and then compressed air to dry it off. I recapped using the parts list from https://recapamac.com.au/macintosh-se-30/. I've confirmed that I've got continuity on all the ASC address, data and control lines, and I assume that if I had any shorts there, I'd be seeing more general system instability (since they'd affect the processor bus as a whole) and/or a strange-sounding boot chime.
Right now my working hypothesis is that something is causing the Sony sound chips (UB10, UB11) to repeatedly toggle the reset line when a sound is played - a bad ground or power supply issue, maybe? - but I don't really know enough about their behavior to know for sure - looking at the schematic, the reset circuitry all seems to be on the other side of the board, and untouched by capacitor goo.
I'm going to continue to investigate and update this thread, maybe solder on some flying leads so I can watch the reset line with the system running - but has anybody run into this issue before, or got any tips about how I could isolate the fault?
