Radius Color Pivot driver
Hi Megabyte!
Which files did you install? It seems that some are for Mac IIs only. My SE/30 throws me an error now every time I want to boot it up.
I will uninstall and re install the drivers today, see if it makes a difference.
That's nice of you! Can you tell me what kind of display you are using with it?
I knew you were going to pick up a 14" M1212 last time. I have one of those (probably dead) so if it works with your pivot card that would be neat!
As I understand, Radius Color Pivot is NOT compatible with extended memory modes on SE/30. I mean MODE32, 32-bit System Enabler and A/UX 3.0
So, only 8 mb RAM with color display, or up to 128 mb RAM but without video expanison :(
Thanks for the info man!
I'm not using any of those, and it still doesn't work... Which files did you install? All three?
Are you running system 7.1 or 7.5?
So correct me if I'm wrong, but you are using 7.1 with 4mb of RAM, right?
And which files have you installed on your system?
The driver from the Macintosh Garden contains:
- Soft Pivot Driver (extension)
- Dynamic Desktop (control panel)
- Soft Pivot (control panel)
Did you install all 3?
Thanks again for your help!!  :)
No, I am using 4x16mb simms + 4x1 mb simms
As I remember, I installed all of these files, but I deleted Soft Pivot because I don't need this functional.
Hi!
I successfully installed Radius driver on my SE/30 and it works perfectly :) I used old NEC LCD monitor for testing, but recently found a M1212 monitor in Moscow and want to purchase it at next week.
I will make a photos (and may be a video) of my setup soon.
Hi megabyte, did you get your SE/30 working successfully with a M1212 Apple CRT?   I am trying to get a SE/30 Pivot to work with Apple M0401, but to no avail.
