Can a SCSI hard drive be attached to the SCSI bus that is used for the CD-ROM drive?
I know it comes with an IDE drive; which I plan on keeping, I was just wondering if I could stuff in a second HDD (the one I am thinking of would be SCSI). Oh, and I would also like to keep the CD-ROM drive too. Now, I know that the connector on the edge of the logic board is a little bit nonstandard, but there has to be a 50-pin connector somewhere for the CD-ROM drive, so using a multi ended cable I should be able to keep the IDE HDD, the SCSI CD-ROM drive, and add a SCSI HDD. Correct?
Thanks
Thanks
