Hi, I´m from argentina, i´m trying to re use my Quadra 900 but I want to know if you can help me or not.
I have my Quadra 900 with Spectrum 8 SIII video card, but i cant make it work. My monitor is a Supermac 20"
If I plug or not the video card, my computer doesnt work. It turns on, chime sound sounds ok but no image.
I tried resetting PRAM (Zap RAM) and nothing happened.
I Tried with a tv with video mode, the on board video out or the videocard............is the same
I can see the hard drive blinking for a while, and then if you press Ctrl + Alt + Supr you can hear a sound from the speaker. It is obviously the system is working.
For a while "it worked" but like the monitor out of frequency, showing lines and differents "grey scale" colours. No chime at start up but that was because i was holding the buttom that is close the reset.
I dissasembled everything. Nothing looks burned or any blowed capacitor. Even inside the PSU
Can anyone hlp me? thanks and sorry bout my english
