Good morning all,
I have been working on my 3rd Quadra 840av, It arrived to me as non working.
The 1st one - recapped - no issues and is working 100%
2nd Quadra 840av - recapped by someone else, and I've recapped it myself in case an capacitor isn't working, but lots of rotted traces, still not working - possible DOA, will sort that out one day, I've put it away for time being.
3rd one - not bad condition - but much better condition than above two 840av's but I have one issue - see below.
It has been cleaned thoroughly 3 times now, It'll fire up, it'll have Welcome to Macintosh, loads extensions as per normal, etc but as soon it launches to Finder before icons shows - incorrect clock/time message comes up then disappears on its own and freezes & the mouse disappears as well.
At first - I thought it was software issue - started up with extensions off - same thing, swapped over to known working hard drive that came out from other Quadra 840av that is running - same thing.
Swapped over VRAM & RAM from other known working 840av - still has issues which leads to focus on the logic board.
Visual inspection and checked like 6 times - it looks okay - like I said above it doesn't really have rotted traces but I can see 3 of them but looks ok/tested for circuits and its ok.
Where else should I focus on the logicboard for possible fault?
Cheers
AP
Cheers
AP
