I'm having trouble getting my Quadra 605 connected to the internet through my LAN and DSL modem.
The DSL modem is a Motorola Netopia 3347. The DSL connection is through Qwest.
I have it connected to the Mac via ethernet to an AsanteTalk, then LocalTalk to the Quadra.
The Mac is running 7.6.1 with OT 1.1.2.
In the TCP/IP control panel, I have set the router address to the internal IP of the modem, set up the name servers (I've tried the Qwest name servers as well as a couple of other open name servers I have access to), and I have tried setting the machine's IP address to either 127.0.0.1 or an IP in the range the modem should accept. I've tried both IPs that the modem may try to assign to other devices via DHCP, as well as IP addresses that it should accept, but will not assign on its own. I have confirmed the IP addresses both with Qwest support and with the configuration information available from the modem.
Looking at the lights on the modem, it does see the ethernet cable in question attached.
When I try to do an nslookup from the Mac, I get an error that "the name does not exist in the name server database." (this takes a while). If I try to request conneciton to a server (using Netscape Navigator 3.0.4), I get an error that "the server refused the connection." I get this even requesting the IP of the modem.
My FreeBSD machine and my business partners WinXP machine both connect through this modem just fine. The BSD box is wired, the XP box is sometimes wired, sometimes wireless.
I'm not sure if the Mac connection issue is a problem with the AsanteTalk adapter, (fwiw, its lights seem to blink appropriately), or with the 10baseT/100baseT swap on the modem, or if it's inherent to the modem, or if I have a configuration wrong.
Any advice, thoughts, comments, or suggestions would be appreciated.
