Problem with MDD FW800 and Studio Display
Jaycen
I have searched the web and looked in many forums and haven't found a problem remotely like the one I’m having.
The problem is with my MMD FW800. It’s a dual processor running at 1.25 GHz with two 80 GB hard drives. The first hard drive has Tiger installed and the second has Leopard. The problem is that when I have a studio display connected it will either not boot or boot into open firmware. Also with the studio display connected, the computer will give a long tone before the initial bong you get when starting up.
If I connect a normal monitor, I’m connecting a Compaq flat panel., the computer boots normally with no problems whatsoever.
I don’t have any USB connections to the monitor, though I have a wireless mouse connected to the keyboard USB.
Things I have tried:
Resetting the Pram
resetting the nvram
resetting open firmware
Any ideas would e greatly appreciated. Oh one other thing. When i first started using the studio display everything worked with no problems. This not booting or booting into Open firmware came on suddenly.
Noting that the MDDs have terribly unreliable power supplies (that can get progressively worse over time with erratic voltages), it could be a possibility that the ADC display, drawing all its power from the MDD, makes it fall over when plugged in. The other thing is the graphics card - which model is it? Can you try another ADC graphics card? Remember that the Apple AGP graphics cards have special connector providing +28V for ADC power, which a standard VGA display does not use - this is the difference.
I'd try disconnecting things like your HDs, optical drive, remove any additional PCI cards, external peripherals etc. to lower the load on the power supply - then plug your ADC display in. Also try blasting any dust out of the AGP slot, and clean the connectors on your graphics card (you can use an eraser).
Interestingly, I found this link while researching ADC which details modding the display for standard DVI signal + use an external 24V power brick:
http://forums.bit-tech.net/showthread.php?t=188336
JB
DId the suggested clean out and it seemed to fix the problem but then it came back. However I did manage to get some more info when the computer booted normally. Apparently the problem started after the computer had a Kernel Panic.
So I'm going to get a different Graphics card and see if that fixes the problem. If not I'll take a closer look at the power supply.
I'll let you know how it all turns out.
