Problem with Mac Classic Analog Board
Hi!
I have a problem with my Mac classic and I need some help:
My Mac classic started to have some display problems and I thought the problem was the logic board, so I bought a new logic Board recapped from eBay. The person tested the logic board and works perfectly. The problem continues at my own Mac classic and I made an apple expert technician in this subject he told me to buy a new Power Supply/Analog. I search in the Tim manual and the part number was: 661-0597. The problem was That the P/N I have found at eBay seems to works fine and was 661-0651 (Rev. B)
661-0597    Power Supply/Analog Mac Classic -Rev A 95.00
661-0651    Power Supply/Analog Mac Classic/Classic-II/Performa200 -Rev B 95.00
Everything fix perfect except the connector form the CRT to the analog Borad. This Rev B board has 4 Pins and the connector I have don't fix. Any adaptor or idea to fix this problem?
This is the connector I have from the CRT (my Mac Classic):
http://www.ebay.com/itm/CRT-Yoke-PCB-Connector-Analog-Board-Macintosh-128K-512K-Plus-SE-Vintage-Apple-/142105600512?hash=item2116276200:g:VhsAAOSw-kdXyWX~
In Rev. A there is a similar Plastic connector.
This is the connector in the new Analog board
https://s22.postimg.org/fe5o5bfb5/s_l1600.png
As you can see, here there is not a plastic connector, there are only the pins...
Any Ideas?
thanks in advance!
