Hello, as some you know I have a SE/30 and I have removed the PRAM battery, but I don't want to put a new one because I'm very skeptical. The thing is that as I use system 6 and I don't need 32 bit addressing because I have 8192 k of RAM (I have the RAMDoubler init that boosts up to 14336 k), and the clock I will connect the machine to the network so I could use the Network Time cdev.
So, I tried to use PRAM Auto-Restore cdev and it wasn't working correctly, if I can remember correctly when I restart and open the cdev again it says like it can't open a resource of some kind.
The thing is, is RAM Doubler that conflicts with the Auto-Restore or is itself that can't work properly in system 6? The page where I downloaded the cdev says it works in system 7.1 and 7.5 and it should work in system 6 it wasn't sure. I didn't try to disable RAM Doubler, shame on me... :simasimac:
