Powermac 6100 pc compatibility card - PCSetup 2.0
Hi,
I have problems with my Powermac 6100 pc compatibility card. I need the PCSetup 2.0 soft registration. I found it on moacintishgarden the soft but no registration.
http://macintoshgarden.org/apps/pc-setup-pc-compatibility-card
I understand that without this soft I can't install any windows soft on the Mac to run the Windows evarioment.
Any help with the registration for this soft? PCSetup 2.0
Any other soft or procedure to do this?
Thanks In advance!
Carlos
Wasn't there a later third party improved version of that floating around a while back?
