Hey so I had a chance to pull apart 3 Wallstreets. I removed the PRAM batts in them before storing them. I was neglecting this and before I forget just had to do it. At any rate I did a recap job on the total of 5 caps in the main unit (not the screen). I did notice a few beginning to very lightly leak. I saw some white dried up electrolyte. It was not bad but just saying. There was 1 - 220 @ 35 volt which I used a radial and bent it to fit in between perfectly on the power board between the bays, as well as 1 - 33 @ 25v which I used a smd tantalum. Then there was 3 - 33uf 35v on the charging board I believe it's called. I actually was able to get 3 - SMD "D" cases on with no issue (from Mouser). Next to do is the screens which I have no clue when I'll tackle that. I hate prying up the delicate front housing. But it's best to do this stuff now. I figured also while the plastics aren't too brittle.
Just giving everyone the heads up!
