All glory is fleeting. I found reasonable looking untested powerbook G3 266. Initially on powering up, chime, hard drive clicked, clicked then a flashing disk on a reasonably good screen. I started up several times (and left it on) with an installation CD for 9.2.2 and 8.6. Great..it works, but need a hard drive. It was an easy, quick change from a broken 4.3 gb to an available 80 GB drive. After the hard drive change, on plugging in the power, the fan immediately turns on and stays on at high speed. No chime, no screen, just fan and steady LED. The power button has no effect. I can turn it (fan and LED only) off and on by pressing shift-fn-ctrl-pwr.I Let it sit with the battery, without the battery, with the old hard drive, without any hard drive, without memory and its all the same...plug in power, fan on at high speed, led on, can turn on and off with the above key combination.
If I take this apart, should I disconnect the PRAM battery and leave it disconnected....what else should I replace while I'm in there. It is a complete dissasembly to get to the PRAM battery...history has proven, I only have a limited number of disassembles before something goes. I do note it is drawing 7.6 watts when the fan is on, but nothing when plugged in and off....but the main battery has never had any LED even after leaving plugged in when it was booting.
