G'day all,
I have came to a problem, My PowerBook 550c (same logicboard as PowerBook 540c) has SCSI2SD for PowerBook in it and if I connect up my external SCSI2SD to it, you cannot get it started and it'll have grey screen with mouse pointer for several minutes then flashing floppy icon comes up. It works fine in my PowerBook 540c but it has a spinner Hard Drive in it.
Turn it off, remove SCSI devices, turn it on - it won't boot unless you put an floppy disk in to boot it up, then restart then the SCSI2SD internal Hard Drive will load up.
I have kept the SCSI ID separate and its not conflicting at all - I have checked like 5 times now hehe.
Why is it doing that? Have I configured something wrong?
Cheers
AP
Cheers
AP
