I have a PB 540c with an active-matrix color display. Everything works but the screen is dark. The brightness buttons slightly make the brightness flicker when pressed but does not make the screen bright.
I've read that I should replace the caps on the screen, which I've done on my PB 180 - but there are no electrolytic caps on the 520/540, correct?
Should i have to replace the backlight bulb, if so, do we know of a common replacement model # that would work?
Thanks!
Thanks!
