I finally got the powerbook 145b to turn on without the sadmac. I was about to throw it out. For some reason I removed the ram card that was attached to the motherboard? And it only turned on with it removed. The display is the issue now. The lcd cable is ripped a little and the screen contrast adjusts but no image at all. I didnt see anything leaked from the screen but I dont know if replacing the screen would fix it or if its something more? Also i heard the simpsons yelling about vietnam or something when it logs in. Is that afterdark?
Thank you
Thank you
