Hello there,
When I got my 145 as usual the first thing I do with a new second-hand computer was to open to check it's internal state.
Bad move on that computer as the ABS become brittle and nearly all the screw stand are now broken, and I can't close correctly the whole thing.
Google didn't give me any clear solution for that sort of problem and I wonder if anyone here had a solution for that, as I do like this computer, but from the need to recap it and the broken shell it's a bit of a pain right now
(at least apart from that it's works quite well, only the contrast is a bit low (capacitors need to be changed)
