I've recently inherited a 1400cs with a peculiar backlight problem and I was wondering if anyone could shed any light on it.
When starting up, contrast usually goes really low and has to be cranked back up again manually. I gather this is not unusual on PowerBooks. Nine times out of ten the computer will then run fine with zero screen issues.
However, very occasionally I have noticed the backlight fluctuating completely randomly - at first just faint flickers, then gradually more and more extreme, on one occasion almost going black for about a second before returning to normal. Restarting solves the issue (temporarily).
On one occasion I also started the machine and was unable to get any brightness out of the backlight at all. The screen simply stayed black.
Are the capacitors in the screen on the way out, or is it likely to be some other issue? Cheers folks!
