PowerBook 1400 can't do IrDA...right?
I've recently acquired a Newton 2000 and it didn't come with a serial dongle.
I thought I could install some software over infrared, but my PowerBook 1400 does not do IrDA according to Low-end Mac.
Can anyone confirm this? Launching the 'Infrared' control panel in 8.6 says 'Not available'. I have to assume this is a hardware issue, but thought I should ask. Is there some kind of software to enable the infrared port to do IrDA?
Thanks
The Powerbook 1400 is using IRtalk, and IIRC this is not compliant with IrDA.
Only used Infrared once, but was between the 1400 and a 5300, never used the Newton (and a control panel must be activated anyway)
Probably won't work, as both units are not using the same protocol, will work with the 3400 or higher.
