Hello
I just got a powerbook 100. It looks good and has a working screen
The issue is the ac adapter port is loose and when i plug it in it makes a static noise with the sad mac sound. I got it to start up to a flashing disk since theres no hd but then back to static noises. Is that because the ac plug is loose? I scrubbed the boards down to. Thanks
