Power Macintosh 7200/120
I recently picked up a few Macs from a recycling center.  This is one of the ones I setup in my office.  I needed a new hard drive and a good cleaning but other than that it works well.  I have 3 others just like it that I will end up selling to a good home.  Plays Diablo very well :)
Had to hook up the Floppy Emulator to the internal Floppy Drive cable to get 7.5.5 installed on it.
Is there a trick to burning CDs that work on this thing?  Can I use my modern Mac?
Burn the CD's at very low speeds, burn them at the slowest speed your drive supports (and even then, support is hit and miss at best)
If you want the G3 accelerator card for your new 7200, let me know. Its small so shipping to Canada should not be too horrible.
I really liked my 7200 until the plastics started crumbling around it. When I merged my collection into one home I had to let it go.
I like to check a flaky or unknown drive with a commercial (pressed, not burned) audio CD. If it won't play without skipping, the drive may be toasted or require thorough cleaning.
I haven't found speed to affect burning.  However, TransMac (with good images) tends to be very effective (via Windows).  That's not always true.  I've had really weird burn failures also; I've never been able to systematically track why.
I think the Toast option mentioned may only be relevant to pre-10.5; and if you have a modern Mac with 10.4 or below that'll probably be a flawless method (I don't think I've had problems using the Superdrive on my G4).
