Power brick for an Asante Mini EN/SC 10T
That would be a different unit, maybe for powerbooks. This has a plug for a power brick just not the voltage and amperage numbers.
I also have an Asante Micro EN/SC designed for PowerBooks, but my guess is it's the same unit with a different design. Mine takes its power from an ADB port, but can also take 5V DC 250mA - ( + from a standard power brick if needed. You shouldn't be far from truth with a 5V brick!
I found that on Google Images:
If it's the same unit than yours, you've got an answer!
