I found a potential simple, cheap solution to the auto-negotiating ethernet issue that creeps up from time to time with the old 10M ethernet adapters/transceivers. All you need to do is use an ethernet cable with RJ-45 plugs wired for the old Cat. 3 standard.
I've been having trouble getting my PB 520 to talk to any of my modern networking hardware. I bought a NOS Farallon transeiver and it came with the original Cat 3 cable that was only wired for two pairs to the T568B standard. I tried the old Cat 3 cable just for the hell of it and it is now talking to everything correctly. I guess only being wired for two pairs the hardware I was connecting automatically knew that it was supposed to default to 10M.
It's pretty easy to turn a Cat 5 cable into a cat 3 cable just by snipping a few wires, so I figured I'd share this and see if anyone else has had a similar experience.
