Did it again , took something down from the attic
This time it is an LC iii - when i opened it there is a radius pivot color display card inside
Cant remember when i got the machine , but there is also a portrait display up there so took that down as well
Recapped the LC and its working great
tried to connect up the portrait display but ive never seen this connection before
ive never powered up this display either , know nothing about them , looking for some advice folks-
why are there 3 ADB ports on the back of the portrait display ?
What exactly does the radius card do , remap the display to fit the portrait display ? .....does it help with graphics ? .... why is there a ram sim on it ?
after some searching the cable i need ( i think ) is a db15 to 13w3 ....... only one i could find is 100 dollars !! , between insane shipping and import charges in ireland these days will prob be the best part of 200 dollars to get to my door
would it be worth the effort and cost to restore this monitor ?
cheers folks
cheers folks
