Hi all, picked up a 575 a couple of weeks ago at the System Source swap meet, missing the HD, so am using the plug-in bluescsi for now with the minimal 7.5.5 boot up, works fine. Was wondering several things about this machine, like how do I get the memory up past the current 36 meg (with 32 bit addressing on, I have about 30 meg free), or should I go higher? The same question about the video memory, is that upgrade-able? What about HD solutions, should I stick with the bluescsi, or is there a better way as I am looking to load software via the floppy and/or CD drive, like Warcraft. I am just not very conversant with bluescsi, but it appears the files you download are iso (?) files that work only with the bluescsi, correct? Does bluescsi allow you to load native floppy and cd files into it for use by the machine? Finally, the logic board was recapped, should I look into recapping the analog board, or just leave well enough alone? Thanks!
