PCMCIA UltraDock - another delightfully crazy .jp hack
Trash80toHP_Mini
NIGHT STALKER
68040
PC-UltraDockの作り方1
http://www.linkclub.or.jp/~maakun/PC_Dock/PCUltraDock01.html
Love it. WONDERFULLY over the inverted top! Always knew the void under the PCB in Newer's UltraDock case was designed for the vaporware PCMCIA dock. This SCSI interface cage is a hack I have very vague memories of seeing.
My twisted take on it:
The 1400's PCMCIA DaughterCage mounted (upside down?) in that void with its IR daughtercard pointing out the back seemed a no-brainer. Either orientation puts the PCMCIA cards fully within the UltraDock as intended with only a WiFi antenna goiter protruding from the UltraDock's multi-purposed plastics.
Been tracing that half the 1400's split I/O bus on and off for what seems like forever.  :ph34r:
GoogleFish version: PC-Ultradock
edit: Woot! Looks like I've accidentally run across the full content of Room of Duuo. I'd thought it had been lost to the ephemeral nature of the WWW.
