PCI 9200 Radeon os compatability?
ive done some research, ive found a couple posts of users running mac os 8.6 with a 9200 but im uncertain if this is 2D only or if it looses 3D/acceleration support?
many report 9.2.2 being the lowest OS that a 9200 properly functions on. is this correct?
my system is a PPC 603e. so it can only run 9.1, right? from what i read 9.2.2 is not compatible. so i may not be able to use the 9200 with out a L2 G3 upgrade card?
would 9.2.2 run poorly on a G3 upgrade (say 250mhz) in a 603e 6360?
it looks like the radeon rage 128 is the most compatible card for os 7.6+ but id like better gaming performance.
anyone shed more light?
