Unearthed my box of old Powerbooks yesterday and tried starting them up. One that did not respond well is a PB180c (the only one I have of that model). Basically, I plug in the AC adapter, wait 30 seconds or so and then press the power button. There's the startup chime, and the screen lights for about half a second, then there's a noise like a relay clicking (2 or 3 clicks) coming from the right rear corner of the base (around where the adapter plugs in). If I try pressing the power button again, nothing. Unplug, plug in, wait 30 seconds, press power, startup chime, click-click(-click), black screen. This worked when I put it in the box (~7-9 years ago?).
Also, somewhere I got a hold of a PB190, but I don't appear to have an AC adapter for it. This doesn't use the same brick as the other PB1xx series, correct?
