Based on some demand, I have finally posted on http://www.mac128.com (index/"Working with XL/Serve & MacServe") a brief basic tutorial for using MacServe to partition any hard drive connected to a pre-System 7 Mac (System 6 has not been tested). Everything you need to use it is there. However, please note that the tutorial is offered as-is for the moment. Eventually there will be excerpts from the user manual to better help explain the complexities of this software. However, http://www.vintagemacworld.com/pu-manual.html#macserve is an invaluable resource for understanding some of the issues facing your use of MacServe. It is mandatory reading before you begin as I describe on my site. I am indebted to Charlieman for transcribing this invaluable resource and all the other excellent work and research he has done on his site.
I have only used MacServe to partition an HD20 and a ZIP 100 drive, but theoretically it can partition any hard drive from the serial port variety, floppy-based or SCSI. The importance of MacServe is that it is the only software I know of which will not only create MFS partitions on any drive (most early hard drives required custom software and drivers specific to their drive), but also allow you to create multiple MFS & HFS partitions on the same drive.
Because of the time involved, please limit any questions you may have to the basic tutorial of partitioning drives for stand-alone use (not networked). I will eventually add more information about MacServe's other uses over time as I can get to it. In the meantime, feel free to experiment with the other features, but use extreme care and back-up often. Since I cannot guarantee the results of any of the claims made in the tutorial, make sure you don't risk any data you can't afford to lose, until you are certain yourself it works on your system as you've configured.
Have fun!
Have fun!
