Pagemaker 3.0 and PB180.
KC13
I asked this on another board, but no luck so far, so I'll repeat my request here:
Hi all,
Here's a blast from the past! I have a PowerBook 180, and an old (read ancient!) copy of PageMaker 3.0. The install proceeds normally until just at the end. I get a message that the Pagemaker file is being (joined, completed, etc., sorry, I can't remember at the moment). It completes successfully it says, but the install program freezes at that point. When I reboot, it shows PageMaker Pt1 and Pt2 in the folder, so the join never really completed. I have tried with all extensions off as well, but no go. Any ideas? C'mon, somewhere in the back of those brains, back in the real dusty areas, someone may remember the solution... I hope!
Someone there suggested I copy to the HD and install from there, but 3.0 requires installation from Floppy only.
My System software on the 180 is 7.5.1.
Thank you
