I overclocked my LC520 from 25mhz to 33mhz following the instructions here: https://www.thinkclassic.org/viewtopic.php?id=600
I forgot to feel how warm the CPU gets prior to overclocking it. However, after overclocking I ran some games for a bit with the rear cover door off. When I feel the CPU it is definitely warm-hot. I can touch it without burning my finger, but only barely. Is that standard for a 33mhz 68030?
I'm guessing it is probably fine. My only concern is that I have the PDS slot ethernet card in place, and while it isn't directly touching the CPU, there is definitely no room for a heat sink... and even if there was, it would basically be transferring that heat directly to the ethernet card.
Can anyone give any opinions or input?
All that said, it ran fantastic for the 30 minutes or so I ran it
Nothing out of the ordinary, and the floppy drive seems to still read and write as it should. I didn't test the serial ports since I have largely moved most of my machines to ethernet or they have access to a SCSI Zip drive, so I haven't busted out the PhoneNet adapters in a while. Does the 68030 have a thermal shutoff to save its self from overheating damage?
