i am running 9.1, just did a clean install on an IDE hard drive to eliminate variables. using OS 9 helper i try to open the 9.2.1 update for install. it gets maybe a second into the loading bar and tells me "error reading disk image from disk". i downloaded the 9.2.1 update from macintosh repository - its the only version of it i can find.
when i try to go directly to the 9.2.2 update it will read the installer, open the next loading screen and tell me that i need 9.2.1 FIRST; that makes sense.
so, im leaning towards a bad image file but i cant find anywhere else with a different file. the 9.2.2 OS disks do not have an updater on them.
anyone have any thoughts as to what my issue is?
full system spec: 603ev with a 240Mhz G3 L2 cache card
128MB ram
Radeon 128 rage or 7000 or 9200 depending on which one i have in system at any given time.
stock IDE or 256GB crucial SSD
TV tuner
composit A/V input card
DVD rom drive
com slot II 10baseT
128MB ram
TV tuner
DVD rom drive
com slot II 10baseT
