Long story short, I scored a 128k for my collection, which I've been wanting for awhile. $100, and local, so not a bad deal, but not great. I probably wouldn't have paid that much, but this one sparked my interest for a particular reason.
Sooo...Show and Tell time!!
Here it is...looking very 'monolith'-y. You'll immediately notice the strange label below the Apple logo...this is what caught my eye.
The back...looks like an early Mac alright...but there's a couple things that don't belong...(we'll get there)
If there was any doubt...Model #M0001
Close up of that label 'Micah Drive AT'. From what I've gleaned from the Google-machine, it's an internal HDD upgrade of some kind for early Macs.
Welp, time to tear it apart! The DB-25 connector comes off to reveal...the battery. No surprise there. A fairly reversible mod. I like that. (Even though I don't have a spare battery door.)
View inside the bucket. You'll notice the fan that was added. I think this is for the 'Micah Drive' upgrade. It connects to a power supply that has been added.
Slides right out...again, a nice reversible mod, which I approve of.
Inside the machine...you'll notice the BNC connector we saw earlier, and the power supply that has been added below the CRT. If you look really closely at the floppy drive cable, you'll notice it's been modified (some wires have been cut). It seems the floppy has been upgraded to 800k, because it reads 800k disks. Handy mod, and fairly transparent. The previous owner thought the BNC connector was a network card, but having seen this mod before, I knew it was a video out. Once the case is cracked, it's pretty apparent.
Close up...the 'video out' port is just a dongle between the existing cable. No soldering, no splices. Again, a very reversible mod. Except for the hole in the back of the case.
Here's what we're left with once the silicon-goop has been peeled off. Not much to it.
The numbers on the ICs have been completely scratched off! Not really a big deal, since it's unlikely I'll be able to even use this thing, but it'll make it harder to reverse-engineer.
Mainboard! Definitely not typical. Two daughter cards have been added...
Obviously, this one is a memory upgrade. Looks like a few chips have been removed from the mainboard, and this card goes in their place.
Closer look...made by a company called 'Compuclinc'
And here is the SCSI upgrade...it seems to go in between the Apple ROMs. I'm not sure if those are the original 128k ROMs, but judging by the date code (1985), I imagine they are not. Maybe Mac Plus ROMs?
Closer look at the added power supply. I think the hard drive piggy-backed along the back of this board. If you look on the right side, one of the mounting tabs appears to have broken off. There was no hard disk in this machine when I opened it up.
Here is how it was tied to the mains supply, which is not a safe way to do it. The Hot is connected to mains ground, and Neutral is connected to the switched Hot. Wrong, wrong, wrong. It works, but it's really not proper.
And finally, here it is running System 6.0.7, showing 1 MB of RAM, just as you'd expect in a stock Plus. Between that, the 800k drive and the SCSI upgrade, it is essentially a Macintosh Plus. Ultimately, I think I'll remove the additional power supply (there's just no need), the video board (that I can't use, anyway) and the fan (which isn't really necessary since it's not a workhorse machine any longer), give it a good scrubbing (it reeks of cigarette smoke!) and keep it as an example of a (more useful) 128k. Maybe one day I'll get a stock model, but if not, this'll do.
