Got a little video related mystery for you all:
I've been testing out my miniature CRT monitors on my QS G4 (OS X 10.4.11, Geforce 4MX AGP video card, VGA + ADC).
Plugging in the "Esteem" brand colour 10" VGA (1991, model cd-1035) works fine (although it's a bit .. meh, as a monitor.)
However, plugging in the greyscale 9" CRT (1994, TUV Product Service GS [unreadable], part no. MA-0933) results in a chime, but no boot, even though there's an ADC monitor present on the other port. I've tested this with two identical monitors with the same result. The monitors (or at least one from the same batch) have previously been shown to work OK on some other system (probably a P4-era or earlier PC/Windows - it was a while ago).
I headed over to pinouts.ru and prepared a table comparing the pins present on each monitor:
Monitor cable end.
Any thoughts, people?
Code:
Pin Name Grey Colour Description
1 RED X Red Video (75 ohm, 0.7 V p-p)
2 GREEN X X Green Video (75 ohm, 0.7 V p-p)
3 BLUE X Blue Video (75 ohm, 0.7 V p-p)
4 ID2 Monitor ID Bit 2
5 GND X X Ground
6 RGND X X Red Ground
7 GGND X X Green Ground
8 BGND X Blue Ground
9 KEY Key (No pin)
10 SGND X X Sync Ground
11 ID0 X Monitor ID Bit 0
12 ID1/SDA X Monitor ID Bit 1
13 HSYNC/CSYNC X X Horizontal Sync (or Composite Sync)
14 VSYNC X X Vertical Sync
15 ID3/SCL Monitor ID Bit 3
