Not a "Classic" Checkerboard Issue
Yea you have a point there. Mine is well water, not city. So could be different.
I should be cleaning my mother boards with well water myself, we have both city and well here as well. I know the water is very clean, I drink it often and it really is amazing. I will continue to use DI because I just don't know how to test any water for contaminates, ions or ohms, but yeah, thanks for pointing that out. Very interesting indeed!
With ultrasonic cleaning I do at work, I keep it all distilled in the cleaning pot with the cleaner.
I still rinse it off with tap water, but I quickly displace the water with a bucket of 90% alcohol so the oxidation from the minerals cannot setup. I do this extra step so the alcohol doesnt get saturated with flux and cleaner causing streaks, etc.
I then bake it.
all my boards come out squeeky clean.
I then bake it.
Sadly I don't have access to an ultrasonic cleaner. Yeah the isopropyl alcohol or similar is a great way to push the water off. In terms of baking, could you provide some details on temp. and duration?
The plastics are the particular concern. What's the average time you bake them for? I have to start using the baking process myself. The idea of a super shiny clean board is very attractive.
if you dont go above 200 the plastic parts survive. its when you get higher than that is where problems are.
a big IIx board would be around 15 minutes max.
SE/30 could take around 10 to 12 or so. getting the liquid out of the ports and under the ICs take the longest.
A good preflight before baking could be some canned air action I suppose. I really like the idea. Thank you for the exchange! I guess we better not hi-jack DistantStar001's original query any longer :)
Another board member recommended 175 (if I remember rightly) but turn the oven OFF before you put the board in and leave it for several hours. I did that with one set of boards and they came out fine. I don't have enough experience to 100% guarantee the method though.
@techknight, where do you buy your alcohol supply LOL? I'd like to use 90% isopropyl more liberally than I already do but the bottle I have (definitely not bucket size) cost a fair bit.
When I say bucket, I mean like a large cake tupperware type thing with a snap lid to prevent evaporation.
We order wave soldering flux all the time, and it comes with the 4662 thinner, which is, yep, alcohol. 1 gallon.
@DistantStar001 everyone has given some great advice here. Best of luck, should be fixable :)
. @techknight and @Alex I generally bake my boards at 160 (lowest my oven goes) for 45 minutes after cleaning. I also do a final rinse with 91% alcohol immediately before baking, so it should evaporate much faster than water anyways. Seems like everyone has their own variation of the process.
