NewerTech MAXpowr Pro G3/266 DIP switches?
I recently got an 8500 with one of these, and it seems to show up as 200 mhz under 7.6. I need to figure out what the DIP switches are then. Does anyone know?
If you are using the fixed-CPU daughter card, the Kansas logic board needs switches 1 and 4 set to ON. Other 8600/9600, and all 8500/9500, 7300, 7500 and 7600 have all four DIP switches set to OFF.
de
Got it. Mine oddly was set to the former configuration, but worked just fine. I changed it to the recommended though, which works great.
