Need Macintosh LC help! (giving no startup bong)
JRL
68000
Alright, I was using my Macintosh LC when suddenly the monitor's image stretched and it immediately showed a grey screen. I had no choice but to turn on and off again.
When I restarted, there was no startup bong/HD activity and no image. :'(
can somebody help?
BTW: the PSU powered on the Macintosh LC; it didn't click. Also, the the battery isn't too old; maybe several years or so.
Thanks everybody for the suggestions; I'll try them later after I let the Macintosh LC sit for a while.
However, I'm suspecting it's the PSU. D: It can't be the monitor, as the hard drive doesn't spin up.
Sounds like you might have to try what Byrd said. I tried that once with the LC II we've talked about, but it didn't work. I just left it on and plugged in for a while until it actually booted up on its own. It seems that it doesn't like to be out of power for very long periods of time (I'm talking like months).
Also, this would help, right?
My Macintosh LC is the same apparent pre-production Macintosh LC as shown here;
http://www.fenestrated.net/~macman/
There is also a giant surface mount cap that has been leaking cap fluid on one of the chips. D: (not all over; just at one area)
In my experience, the LC doesn't respond to bumping; the LC II doesn't require it, either. On that note, the Classic and Classic II don't use it, either. I don't remember about any of the Mac II series, but they were soft-power so they either wouldn't boot period without a good PRAM battery, or would work without issue.
If an LC won't show signs of life, it could have a bad power supply. The voltages may be listed on the power supply's casing, so with a voltmeter it could be tested.
I've got a preproduction model, myself. Mine has a very large radial-lead capacitor soldered to the board (as opposed to surface-mounted) and then hot-glued to the top of the SCSI chip; it also has windowed EEPROMs marked "Apple Confidential" in place of the normal ROM chips. I bought it at a thrift store in Oregon maybe six years ago, along with an FDHD-upgraded Mac II. Too bad I didn't also buy that boxed Laser 128 (which, I found out later, was an Apple II clone) that I saw there later on... I'll upload a picture of the LC's logic board when I find it.
Whoops; I thought that the hot glue was cap leakage. xD It is hot glue on mine too.
There is also a red CUDA button (unlike the normal LC's, as you might know); would that help?
I will definetly replace the PSU. It does turn on; it's just that it won't spin up a HD/give off a display/startup chime.
After working for a bit, it isn't again. :(
It seems like it's the logic board's fault. Does anybody have a cheap Macintosh LC motherboard they can sell me for cheap?
Why not just recap the motherboard? I can do it for $20 plus parts and you play shipping both ways. Any replacement boards you get are going to do the same thing because of age. I have a recapped LC3 on the shelf but you need a LC2 correct?
Well, I really don't have any time, as much as I'd like to do it myself. :p
I need a Macintosh LC board but if I can't find one, a Macintosh LC II or even maybe a LC III board would work, I guess. Still want to keep it stock though.
