Hello,
Finally am cleaning up my Quadra 700. It never had a hard drive when I bought it, so I put in an old Quantum I had laying around.
I'm trying to install 7.1... and I can't figure out how to successfully.
1. I made a disk tools disk that was bootable. Booted to that and created two partitions on the hard drive. HD 1 and 2. I then copied the disk contents to HD 2.
2. Restarted Q700. Booted to HD 2.
3. Insert InstallMeFirst disk.
4. Asks for Install 1. Insert. Copies some stuff.
5. Asks for InstallMeFirst. Then proudly displays the following.
A disk error has occured and installation cannot continue. Your disk may be damaged.
I cannot for the life of me figure out how to get past this point. I have tried using the files off the legacy recovery CD, I have downloaded complete universal 7.1 disk images, nothing is working. What do I need to do?
I've tried creating disks using only the images on the legacy recovery CD, gives an error. Tried using only the images I downloaded online, error. It's always at the exact same place, right after writing everything from disk 2. It asks for Install 1 and then gives the same error every time. Hard drive works fine, it had stuff on it before I erased it. Formats fine, etc.
