All – I'm genuinely flummoxed by this. Have any of y'all seen this happen before? I took a working, recapped SE/30 without a PRAM battery, installed a new PRAM battery off Amazon, and boom – simasimac on boot, no chime, even after waiting for RAM check to complete. Removed the PRAM battery, and I'm stuck with the same simasimac. Would y'all know what might have happened here, or how inserting a PRAM battery in an SE/30 that previously worked might lead to a simasimac?
To make sure I hadn't accidentally unseated a ROM or RAM SIMM, I removed all of the SIMMs, soaked them and the logic board in vinegar to get rid of any corrosion, washed it, and dried it. No change.
Attached are shots of the top and bottom of the logic board, if that would help. They're a little blurry. (Some IPA is still trying on the top shot, so it looks a little bit wet.)
