I successfully applied the hires 640x480 hack on my Color Classic. I've never even soldered before. Turned out great.
My next step is to solder on a resister so I can expand the screen to the edges. The black border is about 2" along the perimeter for it to avoid unmodifiable warping.
Only burned myself twice with the soldering iron. I'll consider those battle scars. :rambo:
I'm also ordering a 256KB VRAM chip so I can crank that puppy up to thousands colors. It currently has a 128KB VRAM, but when I upped it to 640x480, it could only do 256 colors again. I'm heading down to the local computer recycler tomorrow, hoping to find a newer model LC that I can use for the motherboard.
Next project: Solder new capacitors on my BNC CRT 23" Philips monitor. I love that thing, but it's started to get the jitters. Some helpful techies suggested replacing the capacitors and possibly the horizontal and/or vertical oscillator.
