MS Basic 2.0 Help
gavo
Hi,
For some odd nostalgic reason I have started to play around with
Microsoft basic 2.0 on my old (512k) Mac. I'm particularly interested
in any capabilities it has to drive the serial ports for good old
serial communications, however I dont have any reference materials
that describe how to go about it.
I purchased a rather good guide to MS Basic from amazon, but although
its a good reference on how to write code and covers many aspects of
the platform, it doesnt cover serial comms.
I see there are several other old MS Basic for Mac books I could buy,
but I've got no idea if any of them will cover the information I want
either.
So, I was wondering if anyone could either point me to an online
resource, or name a book (if anyone can remember that far back :) )
that contains information on how to do serial comms in MS Basic 2.0
for Mac.
Cheers,
I'm doing this off the top of my head. And I used Zbasic far more than MS Basic.
You need to use the OPEN command and treat the serial port as a sequential file.
OPEN "COM1" FOR INPUT AS #1
GET #1, variable1 ect
OPEN "COM1" FOR OUTPUT AS #1
PRINT #1, varible1 etc
In a statement before you need to set up the COM1 or COM2 port:
"COM1:9600,N,8,1"
I don't remember the exact syntax.
You will need a book for all the verbs and syntax.
Is there a help file?
I used to test my serial ports by hooking up ImageWriter and sendint text to it. If it prints you are doing things right.
I don't have any of my old ZBASIC source code here but I'm sure the syntax was very close if not the same.
open "COM1:1200,N,8,1" for output as #1
open "COM1:1200,N,8,1" for input as #2
This might work as well
Thanks Tony, I'll have a play around with that. I'm starting to think (hope) that the syntax was fairly similar to other Basic's of the era (as you suggest).
Cheers,
