Most common upgrades for an SE?
Unknown_K
68040
I have an SE FDHD, programmers switches, dual 1.4MB drives (will put in a HD when I can find a bracket), Max 4MB RAM and was wondering what else I should get for it.
What are common PDS upgrades for this unit (ethernet card maybe)?
There were two RJ-45 Asanté MacCon ethernet cards, unique to the SE (MacCon+ SEET and MacCon3 for SE), which are even scarcer now than those for the SE/30.
This one does not have RJ-45.
For a knockdown on other upgrades for the SE, mostly seen only in dreams nowadays, look at Low End Mac.
de
lowendmac says "The SE was the first compact Mac with an expansion slot. One of the first add-in cards was an MS-DOS card. Over time, video, ethernet, and accelerator cards became popular accessories."
I've never seen any card for the SE other than the Asante ethernet cards. The lowend mac site also lists several "Accelerators & Upgrades"
http://lowendmac.com/compact/se.shtml
Also, I'm 90% sure that ethernet card you're asking about has an RJ-45. I think that's the same card I have, although I think it might be called the MacCon SE+, not the MacCon+ like the seller claims. Wish I could go double check. No doubt someone here knows for sure.
I'm looking at the one equil says "does not have RJ-45" and it sure looks like it does to me. AAUI, BNC and RJ-45 is what I see.
Nathan
... I'm looking at the one equil says "does not have RJ-45" and it sure looks like it does to me. AAUI, BNC and RJ-45 is what I see.
Consists of 2 pieces. A main card plugs into the PDS slot of the SE. This card is attached via a ribbon cable to a bracket at the rear of the machine. This bracket has a Thin Coax and AUI connectors (but does not include the RJ-45 connector shown in the picture below). The AIU connector is converted to RJ-45 (10 Base T or twisted pair, as you prefer) via an adapter included with the card (not shown in the picture below).
The info. about Asanté cards came from the MacCon card manual. The quote from Olde Mac Milt came from the referenced eBay page.
... (will put in a HD when I can find a bracket) ...
There is a good chance that you can get the HDD metalware from Olde Mac Milt's eBay Store.
de
for what it's worth, it's hard to find the "dual floppy AND hdd" bracket, because it was a third-party add-on. I have one made by Jasmine, but it doesn't fit modern drives properly and the old drive that came with it croaked.
I'd look for an Ethernet card, Radius 68020 upgrade, or a GPIB interface, if you're into that sort of thing. An SE with a GPIB card would be great to hook up to an oscilloscope or function generator for just datalogging.
I was going to rip the 2nd floppy out when I install the HD, just need the bracket. I have a GPIB Nubus card, but nothing to connect it to so it never gets used.
So basically I will have to find an ethernet card or a slow processor upgrade for it.
I could also keep it as dual floppy and get a small external SCSI HD for when I need it, would be quieter. Might bring it into my room and use Think Pascal if it runs on a 68000 with 4MB.
You can slide an SE/30 logic board in for a nice speed increase, although you'll also need to either get the rear shell of an SE/30 case or modify your existing case if you want to use its slot.
If I wanted to make a really impressive SE, I'd get one of those Radius 68020 cards that has 16MB RAM expansion and full-page mono video. Build an adaptor to make it drive a modern monitor and you'd have a real nice machine.
A slow 68020 accelerator is still hella fast in System 6.
i have dual floppy and HD with the standard bracket... it fits when you are careful and dont want to use afull height HD.
Those brackets seem to vary. I've seen some with full size 3.5" drives in them while others were only able to fit a lower profile drive (that one had a drive pulled from an LC II in there).
I have a SE with dual 800k floppy drives. Would it be possible to slip a 2.5 hardrive from an early powerbook with an adaptor to fit the 3.5 hardrive plug, into a dual floppy case? Also, to change the 800k's to 1.4, will there have to be any other mods to make the 1.4's work? I was surprised to see, that there was a dual 1.4 SE made!! I have a couple extra 2.5 harddrives and 1.4 floppy drives as spares, just thought I might be able to put them to use.
The SE FDHD has newer roms and a newer floppy controller chip to use 1.4MB Superdsrives, it came out a while after the SE.
No idea about the 2.5" drive.
yep.
to make 1.4mb drives work in an original SE you need new ROMS and you have to replace the IWM with a SWIM. I did that on my SE board with ROMS from another dead SE.
you can put a normal 3.5" HD on top of the 2 floppy drives. so that there would be no need for an adapter.
Thanks for the tips. I think I will leave the 800k floppy drives alone and concentrate on putting in a harddrive. I will keep an eye on ebay to pick up an upgrade for a little added speed!!
