I just picked up an old Miniscribe 8425S SCSI drive, which sadly doesn't work, so I figured that I might be able to repair it someway.
It spins just fine, but it doesn't mount. When I want to format it with a HD SC Setup 7.5.3, it shows as uninitialized, and when I try to initialize it, it tries to initialize it for about 3 minutes, and then it fails (Format verification failed).
If I test the drive, it makes a "searching" sound, and then it says it failed its test because of the problems verifying data on drive.
In The Dead Mac Scrolls, it says that it might be repairable with DiskManager Mac version 2.24, which I don't have.
What do you think? Is a drive a dud or it might just be salvageable somehow?
