Mini vMac for iPhone
zydeco
I just deemed my port of Mini vMac to the iPhone worthy of releasing, so if anyone has a 2.x Jailbroken iPhone and wants to try it, you can post your opinions here.
To install it, add apt.namedfork.net/iphone to your Cydia repositories and it will show up.
You can also see the info page at http://namedfork.net/iphone/minivmac, it says where to place the ROM and Disk Images, and how to use the two finger gestures.
UPDATE: I added sound emulation and made it a bit faster, among other things. The sound can get a bit choppy, there's a switch to deactivate it in the settings. Also, it works in OS 2.2.
Man, I just played Shufflepuck on my iPhone, I did it!
This is nothing but the HolyGrail, seriously. I love you! Thank you so much for that wonderful port!
Works great! A lot of clever ideas.
Can't think of a lot more to say right now, but I'll sure keep you updates with my thoughts as I play some more with it!
I just deemed my port of Mini vMac to the iPhone worthy of releasing, so if anyone has a 2.x Jailbroken iPhone and wants to try it.
Assuming Apple's SDK Apps will not support Mini vMac? Have been hoping someone would look into this since Apple announced Apps.
Hmmm, this might be the final push I needed to re-cydia-ify my touch; after 2.1 came out I never bothered with doing it again.
Do you have any reports on battery life?
What do you mean by SDK Apps not supporting it?
The battery life shouldn't be affected unless you install programs that run in the background, like Scrobbled or MxTube.
Also, 2.2 will be out soon and is predicted to be jailbreakable, I hope it doesn't break app compatibility too much.
Oh, and I made a video :beige: :
I think he was asking whether it would be possible to build vMac using the official SDK, such that it could be used on non-jailbroken iPhones and release on the App Store.
Yeah, that's pretty much what I was asking.
Actually, Apple would most likely NEVER allow Mini vMac to be posted on the App store anyway and it probably wouldn't do Mini vMac project any good to bring too much attention to it at Apple.
What I'm waiting for is a way around installing Apps on the iPhone outside of the App store, in much the same way there is software that allows ring-tones to be installed on the iPhone outside of iTunes.
What are the implications of Jailbreaking the iPhone these days ... ? I have so much trouble with mine as supported by Apple that I couldn't bear to deal with any more problems.
Mac128 great icon anyway I would use less glow and shadow ;) and why platinum? is it platinum plus? is it too small to write Macintosh Plus on icon :)
I can't wait until Mac II emulator comes with colors :p :p :p
It does not comply with the App Store agreement in several ways.
  1. It uses private/undocumented frameworks (for drawing video, it's the only way to get decent speed)
  2. It reads/writes out of the application sandbox (this could be changed by implementing a way to send/receive files within the app)
  3. The icon isn't square (easily changeable)
  4. It runs interpreted code (that's the purpose of an emulator)
And about installing unofficial apps without jailbreaking:
I don't think it can be done, since the iPhone only runs code signed with Apple's keys, and that is one of the things that jailbreaking patches.
I - sadly - don't think that will ever happen on a non-jailbroken iPhone…
In my experience (iPhone 3G, jailbroken from a recent Intel Mac this summer), it's VERY straightforward, using the "official" Dev-Team tools. So easy I was nearly frustrated…  :)
great job on the emulator!!! I've got a quick question. I made a 50mb disk image using hfv explorer, when i run it on minivmac on my windows laptop, it isnt locked, but when i run it on the ipod touch, it is. Any suggestions?
If you copied it with SSH as root, you'll have to change the owner to "mobile" (and permissions to 644 if it still doesn't work)
Are you referring to my avatar or the Mini vMac icon?
My icon is of course the classic 128K and is PMS 423 beige.
The Mini vMac icon is both a Plus and platinum as Paul Pratt prefers the Plus icon given that the Mini vMac technically emulates a Plus. It also emulates a 128K & 512K, but that is a build option. The default option is a Plus. Also, platinum is the universal color for all Macs after 1986 and was the color the Plus was the longest. There was room to write Mac Plus, but at the scale it was reduced to, it was completely unintelligible and Paul preferred the cleaner version. As for light and shadow, it was designed to match the OS X icon style and ultimately signed off on by him. It still remains a build option and not default, since Paul still clings to the smallest possible files sizes which OS X graphics inflate unreasonably.
I'm a little hesitant of jailbreaking my ipod touch (v2.1), maybe you can answer a few questions for me......?
Will I still be able to use App store with a jailbroken touch? Are there any "bad side effects" that occur? (will it affect any Apps I already downloaded?) To "un-jailbreak" the ipod is it just a case of zapping it with iTunes? And finally....are there any "must have" apps that I can only get with jailbreak? (is it really worth it???)
Slightly off-topic… But for the sake of winning a future mini vMac user:
Sure. You won't loose any functionality, only win a lot more!
No.
Yes.
Well… mini vMac for example! A complete Mac Plus in your pocket, sure it's worth it! :)
I myself use only two others apps: Cycorder (video recording) and PDAnet (iPhone as modem to surf anywhere with the laptop).
Edit: usual disclaimer… I can't be held responible, etc, etc. It worked great for me, as I used the official QuickPwn utility from the iPhone Dev-Team, followed all of their instructions and backed up my data first!
