Yeah, I figured most everything out, equating CardBus with PCIe in terms of the the MacBook slot was all I needed.
I'm used to PCMCIA and CardBus being used interchangeably with PC Card by now, that was going on ten-fifteen years ago, IIRC. The vast majority of Laptop users today have never seen, nor heard of, a Laptop Beast that has a 16 bit "PC Card" slot that won't let itself be damaged by the insertion of a card with the gold stripe.
Now, I'm on the prowl for a Mini PCIe internal card <-> PCIe external card adapter . . .
Question: once my PCie <-> PCI Slot adapter gets here, will I find that PCIe is backwards compatible with PCI to a limited extent. I'm ASSumIng that a full size PCIe Slot would be a super-set of PCI Slot function, signals and speed?
I still don't know (idle curiosity) if the Pismo's CardBus slot it is X.3 Compatible.
p.s. I have the info on wood pulp based storage media and Google at hand for this kind of info, but I figure it's good to get this stuff into the record.
Then I can then link to it in the (theoretical) 68kMLA Thread Link Addendum to the Peripherals Links Project . . .
. . . on top of being lazy and only casually curious at this point. [
