microSD & SD Extender/Adapters
Overlord
So my SE/30 build is going to have a FloppyEMU C and a SCSI2SD V6 mounted internally. I want to route their respective microSD/SD cards to the back of the case for easy/attractive access. I've seen many different micro-sd to SD extensions and SD card extensions on many different sites. Are there any specific ones that anyone can recommend? Or perhaps any knowledge or advice they'd like to share?
