I'll do so, but take your time, it'll be a while before I even have time to open that box, it's 1400 fun time.
NOT A RECOMMENDATION!
I thought I'd made another major Zip conquest a while back. I picked up a pair of
internal SCSI ZIP 250 drives, but they haven't worked out very well yet. :-/
I picked up a pair for $100 shipped with high hopes and the drives work fine up until the it's time to dismount/eject the disk. I've only tried them with iomega guest on a few different OS versions and once on a system with a driver install so far, so there's still some hope.
Pretty cool find nonetheless, might work out as a 250MB boot drive for compacts. Less power and heat than adapted SCA drives I would think. I haven't bothered to try it out yet, but they
may fit underneath the FDD in a Compact. I'm pretty sure you'd need to do a nasty power switch shutdown method due to the dismounting problems, but it
might work out. If someone wants to do some serious research on them for this purpose and for the driver issues, I'll gladly loan one out.
