Okay,
I did some reading yesterday about the SE. Seems the SE was the improved Plus. It works between 10-20 % faster, option for internal HD, later models with Superdrive, PDS slot, "better" cooling. Improved on almost all aspects.
But, why does it only support up to 4 MB like the Plus? Or, are there easy hacks to get it use more?
Then, could a power supply from a late SE serve in the SE/30, since I will need to replace it in the long run and prices are in favour of getting an SE than shopping for a replacement part or a SE/30 on ebay. Couldn't find reliable info on the net plus I'm not much of a technician (yet) to know what to look for to be compatible but Watt&Volt.
