Macintosh SE/30 no Display
bibilit
68030
Logic board issue for sure, new caps, I have a chime but screen remains black.
Ls166 replaced, traces checked around but have not found so far.
Any idea ?
With another logic board, screen is ok.
Trying to figured out...better but not over.
After replacing UG8, screen lit up, and had a display (sort of) but UE8 was bad also, after replacing this also, the display improved, but was very dark.
I patched a trace, and now have this screen.
The more i use it the worse it is.
Sound is present and board is working (can boot from a hard drive) but after a while screen is really corrupted.
Any idea ? As I have been spending hours already looking for broken traces.
In the end my new LS 166 was faulty.
After removing and replacing the F 253s I get back to the LS and removed one from a damaged board, worked perfectly.
