Macintosh SE/30 Digi-Key Capacitor List
Awesome. Great idea. Although I like to use mouser because they have the correct axial capacitors. But either way, it all works.
Thanks, I had no trouble finding the Logic Board cap list but the A/B and PSU proved more of a challenge so I figured I'd make a quick solution more accessible!
Hi,
I'm not living in the USA and when I open these lists I get zero items.
Can somebody please print these lists as pdf or text file, so we all living elsewhere can participate in your work?
Thanks!
Interesting. It seems to work for me, but it looks like there's a javascript or something that loads the items up. Can you check and see if you have an adblocker or something that may be preventing javascript from running? The way it loads looks a bit like a popup blocker ay flag it..
Can you check and see if you have an adblocker.
Yes adblocker, pop-up blocker were on, but also didn't work without them.
Maybe it's because the links don't open the US sites for me but sites in my native language, which contain zero items then.
Hi buddy, same Didn’t work for me either in the uk but the pdf. Version opened just fine :)  Could i ask as I’m about to recap my analogue board and power supply in my se/30, ive read the one cap near the fly back isnt the best and could be upgraded, did you upgrade it if so what the value you used or did you just replace all like for like? did you also re solder the high voltage areas like the cable socket as i hear they can dry out and crack due to temperature and voltage over time. Im no expert and a bit anxious about doing it, did you have any issues or recommendations?
many thanks Neal
